Capri to ST
CHAPEL HILL, NC, USA
Lugnuts are swollen (giggity) so probably should replace them. Anyone got a Mcgard part number handy? They’re my go-to.
I'm using McGard Spline Drive Lug Nuts, P/N #65357BC, and like them a lot. I've had them for almost eight years and they've held up well, they're tough.
This is on my aftermarket wheels. I think they fit the OEM ones too, but I'm not sure.
Here's a link, they're sold many places, and come in other colors-
https://www.maperformance.com/produ...e-cone-seat-lug-nuts-chrome-blue-caps-65357bc
Pittsburgh
Thanks but I prefer regular hex ones. I dig the blue end tho, that’d be sweet.
KXNGABE85
U.S. Coast Guard Veteran
Florida
I'm intrigued by the dynamat, it really that made that big of a difference?
100% Dude I am not kidding, I am currently just to list a few mods, CPE Passenger and Trans mounts (NVH is real with these guys lol) lots of bracing both from and rear. Vibra Technics RMM because CPE as out of stock lol. About 5 braces in total if I remember correctly, removed the spare out of the back and everything else in it. Rear Muffler deleted and a sound system, all components plus rear sub that weighs 45lbs by itself and the difference in sound is UNREAL.
I never realized how loud my car was until I put that sound deading in the back. I guess I never really thought about it, I knew I had rattles but with those rattles comes a lot of increased noise and I just never put the two together, is what it is. But when I cranked the motor for the first time after putting the car back together I couldnt believe my ears! Even to this day, I notice it right away like I can't believe how much quieter the cabin is compared to what it used to be, hence why I will be doing the rest of the car in the near future. I honestly don't think you will regret it. My two cents ✌️
Dialcaliper
San Francisco Bay Area
I also like the mcgard spline drive nuts. Narrow profile is great for aftermarket wheels and the spline teeth hold up better than hex flats if you are repeatedly removing and replacing wheels yourself, which I tend to do.
The integrated taper washers are what really make them great. I find that I’m much more able to get a reliable torque on the first go around (always do three passes), and rarely do I ever get any movement even after a test drive or checking a day or two later. Because of the washers they don’t bind like steel-on-aluminum does
Yes, a ton of sound enters from the rear. Of interest, the cowling assembly beneath the windshield, is also responsible for a huge amount of sound deflection from the engine bay.
Pittsburgh
Installed a Cobb RMM and a whoosh ricer plate.
  • Mount feels good. Haven’t been on highway but haven’t noticed any increased noise. No more squeaky action when I take off or shift at low speeds.
  • Ricer plate is a bit loud and silly for first and second gear but it’s kind of a silly little car anyway so it kind of fits.
I’m pretty happy. Haven’t done much else in a while. Lugnuts are swollen (giggity) so probably should replace them. Anyone got a Mcgard part number handy? They’re my go-to.
Went back out this morning and changed out the passenger blend door. Thanks for the info here on that, I initially bought the ford part that ends with A thinking I needed the driver side one. After more reading I realized that it was the passenger side I needed. Then I carefully read through the threads here this morning and realized I made the same mistake as a few others and misinterpreted the diagram so I accidentally bought the right part. Went right in with no issue. Opened up the old part and confirmed broken gear teeth.
I then replaced the cabin temperature sensor because once in a while if I shut the car off and start it a few minutes later, the auto climate control has lost its brain and blows AC full cold at 50% fan no matter what the temperature outside is. Hopefully that fixes it and it’s not a control unit issue. The old sensor was full of dust and hair so hoping an improvement.
After a test drive, the motor mount yesterday didn’t fix my squeak when I clutch in and out when it’s cold. It’s coming from the front passenger side. Is there maybe a mount there that’s going or maybe it’s the upper strut mount? Any ideas?
Pittsburgh
Welp interior sensor didn’t fix it. Ran a quick errand and when I got back in the car, boom, blasting AC when it’s 40 degrees out. Yay electrical gremlins. At least you can still manually turn the temp to high and control the vents and fan manually. So it’s more annoying than anything and doesn’t happen for my commute or anything since it sits a while.
pixelzombie
Chicago, IL, USA
It's a tight fit for the spare with just rubber to metal. Is the material thin enough to still be able to fit the spare in the trunk?
anticon
Sherwood
I swapped for my all-season tires and replaced the factory fog lights with Diode Dynamics Elite in yellow. Definitely an upgrade over what I had with the stock lights with auxbeam LED's and yellow laminx.
Ontario, CA, USA
Noticed a coolant leak about 2 weeks ago, tracked it down and seems it’s coming from the thermostat housing. Got a new one for $60 and also going to replace the bypass valve that bolts to it. Might as well throw in a new thermostat, I believe the new one comes with one but I doubt it’s the 180 degree one.
SteveS
Osage Beach, MO, USA
Took advantage of a sudden warmup yesterday to swap the summer tires for the snow tires yesterday after church. It got up to 74 degrees. After I finished with the tires I winterized the boat, then took the Miata for a top-down cruise down a twisty, hilly state road and back before settling on the couch to watch the Las Vegas F1 race (recorded). Overcast today and then by Thursday down to 40 for high and 20 for low, so perfect timing!
