Yes, that one. Most people like it, but some, like @Dpro do not. They agree that is is angled to close to the driver's leg. That is why I like it. Even if it only angled straight back, I would still love it. When I went to STOA and got in the FoST, I was like, WTH, why is the shifter so high and on the passenger's side?!
@Dpro, since the Boomba is only the shift lever, and it uses the original housing, how is it more notchy than factory? I could see how it could be more notchy than a whole new Mountune block mechanism. They must have a different design that gives it that feel. I am also in the opinion that depending on the reduction amount or the reduction combined with a short shift Adapter, that it could feel more notchy. You have to move the cable close to the same distance, but w/less throw. I say this because I already had my adapter at 25% and when I added the lever, I didn't want to have to go back in and set it at 25%. Yeah, combined 40% is a SHORT shift...too short for my preference. And yes, notchy. I'm going to adjust the werks adapter to 15%.
I drove a persons car with the Mountune alone and liked. I sat in a car and tested the Mountune and Boomba combined and it felt notchy which I don’t like in any car. They probably had the combined 40% or more. Which is what I drew my conclusion from especially based on what you are saying. Perhaps I would feel different If I shifted a car with the Boomba set to less than that.
Thing is I personally do not feel the stock shifter in our cars is that bad for a stock shifter in what is a Hot Hatch. Its actually pretty good.
I got the Mountune for free ( yup won it ) at the Mountune Meet a few years ago. I have not installed it yet because its not been a oh my god this shifter is so long throw it needs to be shortened.
I have seen longer throw shifters in the past on cars and this( the stock shifter) is nice in comparison.
In fact its reasonably precise with decent throws for a stock shifter.
I will say after testing the Mountune in someones car I will install it but its not high on my priority list in mods for my car. I have bigger fish to fry so to speak. One of these days it will get tossed in and I will post it in my build thread.
As far as Honda/Acura’s being the best shifters in the world whoever said that I cannot agree with it. They are good. They are completely in the wrong place in the tunnel though way too far forward almost into the dash. To me that is strange. Though Hey I am a RWD guy and used to the shifter being just forward of the seat edge not up in the underside of the dash. :LOL:
I also personally would not get caught dead driving any Honda/Acura outside of a NSX or their Motorcyles. Thats from being a Japanese RWD car guy thing. What can I say call me biased.:LOL:
brbauer2
St. Charles
82500 miles and it happened.
Figure I'll punish myself a little extra and do the cabin filter while I'm struggle bussing...get the frustration out all at once.
Sent from my KB2007 using Tapatalk
flbchbm
Sterling, VA, USA
Put my Tail of the Dragon vinyl on today. The orange matches my paint pretty well. Car is filthy though. Haven't cleaned since the trip.
Sent from my Pixel 2 XL using Tapatalk
Sorry Brian, I can't help myself. I love southpark so much. Tell me to stop the meme if you want me to. No worries.
Mountlake Terrace, WA, USA
New tires installed Falken Azenis RT660.
If you are interested to see what the OEM summer tire looks like after 15,000 miles I took pictures.
Just a thought, this is pretty well covered in many locations on the net but I just copied this text.
Are your “tire dots” where they should be?
Tire manufacturers recommend the correct positioning of the red and yellow dots with respect to certain “landmarks” on both steel and alloy wheels. These dots can be used to mount tires for optimum initial balance and minimum ride disturbance – where the dots go depends on which dots – and which wheels you have.
First, if the tire has a red dot, the yellow dot is ignored! The red dot is then lined up with either the “low point dimple” (on steel wheels) or next to the valve stem on alloy wheels. Regardless of the type of wheel, if there is no red dot, the yellow dot is positioned next to the valve stem.
Why do the tire dots go where they do?
Simply put – the tire is a bit lighter in the area where the yellow dot is located, and a bit thicker where the red dot is located. On an alloy wheel, the valve stem marks the heavy point of the wheel. By matching the light point of the tire with the heavy point of the wheel it’s likely to give the best initial balance.
Ford ST
Pleasant Garden
They are balanced just fine overall less weight than the OEM set.
Discount tire uses excellent tire balancers.
"We have found that the only way to accurately match mount replacement tires on used original or new aftermarket wheels is to use Hunter tire balancers which have the ability to measure force variations under load before the tire and wheel are installed on the vehicle. Using these machines, the colored dot on the tire might be positioned anywhere on the wheel relative to its runout measurement. In the end, the markers have little, if any, relevance."
https://m.tirerack.com/tires/tiretech/techpage.jsp?techid=242
Ball Ground, GA, USA
After I wrapped up my day I headed to my brothers shop. We successfully installed the Fortune Auto 500 coilovers, Whoosh IC, Velossa Tech Big Mouth, and a couple of rear tow points.
We did not cut the top of the strut towers. We set both camber plates to 0 on top and went from there. I'd rather dial it in by removing the struts once as I won't likely need to make camber adjustments often. Height adjustment was interesting. Not difficult, but time consuming. I blame him for messing with them and not spending the time to read the directions and listen. I'm the "slow down, read, plan" person and he's the "figure it out as we go along". So we had to lift, adjust, lower, lift, repeat a million times.
Finally set ride height and then worked through the alignment. Still some tweaking to do and I scrubbed the left front under compression on the drive home. So clearly a bit too low... Speaking of the drive home, it's about 15 minutes. And in that 15 minutes I can say with certainty the car is way more compliant. Hard bumps would previously send shockwaves through the car and that's reduced completely. It's unreal and exactly what I hoped. Obviously I'll get more seat time and more tweaking will be necessary.
The IC wasn't a big deal to install. He did my radiator so this was my first time getting the bumper cover off. Nothing crazy, just finicky. I did the black Whoosh IC and it's very well done.
The Big Mouth was a pain. Mostly capturing the nut to tighten the bolt. Looks great though.
I'm excited to see it all in the daylight. And of course the car now has fingerprints all over it. So a wash this weekend hopefully. And new brake pads going on.
Overall, very pleased. Just the LSD to go...
Los Angeles, CA, USA
That's the one. It's described as having an additional 30 degree bend to position it closer to the driver.
I'm okay with the Mountune Short Shifter and I have the bushings to install. But if the Boomba dials in some additional precision and shortens it up some more, I'm down. Just not certain I'll like the angle.
Yeah it's personal preference for sure but I'm 5 foot 6 and have 15 inches from elbow to finger tips and I find the position just fine. The additional 30 percent just makes it feel like it should have been from the start. I was unhappy with the throw by doing the other mods it just wasn't enough for me. I hope some of this helps I personally have it as one of my tops favorite mods next to the motor mount inserts I did the yellow ones and that actually helped with shifting feel as well especially when in a corner. Made a huge difference in handling I was actually kinda blown away and very little noise and vibration which was why I went with the softer compound. Anywho I'd say pull the trigger I'd be very surprised if u were bothered by it cause I barely noticed the positioning change but I sure did notice the decrease in throw. But if u are a bigger guy then it could be more of a thing. Good luck
Sent from my SM-N986U1 using Tapatalk
Sam4
West Chester, PA, USA
Strut mounts today to replace the china mounts I bought when I swapped out to Bilsteins. The chatter is unbearable - not even ACDC helps! Motorcraft instead of Happy Family/Bluebird/CrunchyFrog brand, but I don't see any difference except Moto is a little heavier?
