Install complete
Here are some pictures of my install.
The HID kit comes with a wiring loom, switchback turn signal LEDs, two ballasts, and the retrofitted HID headlights. These headlights have an LED strip along the bottom of the headlight. This requires wiring them into the OEM connector. This is what the passenger side connector looks line. You want to tap into the parking or running lights.
This photo shows which wires you need to tap into. It is the same two wires on the drivers side. Note, the colors are not the same on each side. The wire to the left of the parking/running lights is the flasher wire. If you install switchbacks and you want to slow down the flashing speed, you wire one end of the resistor, or a length of wire that, in turn gets wired to the resistor, the other end of the resistor gets mounted to a metal surface, and the other wire gets grounded to that surface. Make sure you solder all connections because the resistor will get very hot.
These are the wires to tap into.
This is the drivers side. The wires on the top row, third from the right end is the parking light, and second from the right is the ground. I used an exacto blade to peel the insulation away.
Passengers side
Drivers side.
I purchased a two pin waterproof quick connection, and soldered it onto each plug. I used electrical tape to cover each solder joint. Then split corrigated wire cover to make it look OEM. This is the passengers side.
I wanted to mount the ballasts as near as possible to the lights since the 5000K connectors from the headlights are pretty short. I made up some aluminum panels, drilled out two holes to mount the ballast, and drilled the holes in the passenger side, on the frame.
I had originally thought the balast would fit on the crash par part of the frame, so I bent the passengers side plate, but that put the plugs too far from the headlights, so I unbent the plate, and mounted it as shown. This is the passenger's side. I used industrial strength velcro to mount the hardware coming out of the ballast to the plug.
On the drivers side, I mounted the ballast between the body and the washer fluid bottle. I used the fasterner that holds the washer bottle and drilled a hole, and secured the ballast with that fastener.
I put all of the wiring between the upper and lower rear cowl. Then I cut into the lower cowl to allow the wiring to pass through to the battery, the passengers side, and the drivers side.
I had pulled the negative battery terminal before I started, so I wouldn't create any problems with fuses or wires. I wrapped the terminal in a shop rag to prevent it from touching anything. I wired the positive terminal to the battery, snaking it around the battery, and attaching it to the positive terminal. I needed to trim the positive terminal cover, to allow the cover to fit with the extra wire. I attached the ground to the ground on the passengers side, then I attached the rest of the plugs (Ballast plug on both sides, trigger on the drivers side, 2 pin plug for the LED strip light), and the OEM plug to the headlights. I started the car up, turned on the lights and everything fired right up. Everything except the switchback LEDs and one parking light. I had to pull the switchbacks and reverse them, and replace the small bulb at the top of the passengers side, headlamp. I installed the headlights, the upper cowl, the wiperblades, and took the rest of these photos.
Most of the time it took to install these lights was consumed making decisions how the ballasts were going to be attached, how the wire was going to be routed, and then actually doing it. In the end, the headlights came out looking great, and the wiring routing looks OEM, which what I was going for.
