MBT is not a function of fuel and it has already been dyno-tested to be correct. Just because someone can't achieve it on their local pump gas doesn't mean that we can add boost and reduce KS input and then go above it. Changing a turbo doesn't change MBT, and going above it is just adding stress. And no, the factory calibration is not going to ask for nearly 18 degrees of timing. People aren't going to understand that today, but maybe in a few years once the cumulative stress finally takes its toll.
I think it's funny that we're still adjusting KS sensors for 'RMM false-knock' when no one on this platform has actually experienced it. The only people ever actually claiming false-knock are select tuners, and I've worked with multiple members to show them why their false-knock was actually not false-knock, despite what they were told. But hey, the more people that are willing to let themselves be kept in the dark, the more it's their fault.
What makes you think that Ford's OE calibration doesn't have MBT at 18?? It's never hit, nor will it ever be on a factory cal. Also, I'm referring to MBT in regards to tuning, not the MBT for the engine itself. MBT for ones fuel type/turbo/airflow is going to be different for what Ford designates as maximum torque for the engine. No more torque, no more timing, reduce until same results are achieved. MBT for the engine is indeed 18?, which as I stated is never achieved.
Because you brought this up, I would like to get your input on what you think MBT is for the 1.6L regardless of fuel and configuration.
You wouldn't believe how many times customers have said "why is timing so much lower than my previous tuner". I respond with, because it isn't needed. How does the car feel? 10/10 times they say "much better".
Determining rear mount false knock was pretty simple, and like I stated my reducing is very very minor as it isn't as big of a deal as people make it out to seem, just like you stated. I have spoken with other tuners and they are going as low as 8, which is just...well completely dumb. I work with a lot of shops around the world that aren't familiar with tuning the Ford Ecoboost platforms. Then send me over the calibration they are using and having problems with and I go through them, then have a remote session with them showing them their mistakes. They compensate me for my time and that is that. This has been done with even my competition for e-tuning, and I have seen some thing...unspeakable things..
Log raw data with factory engine and mount, log raw data with factory engine and aftermarket RMM, no other variables. Read, compile, adjust. I did mine with a 100% factory car with 10 miles on it, then again with a factory car with 18,000 miles on it. Then installed RMM's on both, and compared. This accounted for "break-in" on the mount, just because.
