I have pulled and rolled using a Eastwood roller, loosing the front fenders allowed me to fit 225/45/15 Hoosier A6 on 15x9 wheels with -2 deg camber. Those tires are more like a 245 wide in reality.
Then I went to the rear and found I would have to do major surgery to fit them so I got some 225/45/15 Toyo RA1 tires that are more like a 230 wide and with modified rear axle and as much rolling as I can get done just get them to fit the rear.
The fronts ended up further out than needed so I just loosened the bolts and pushed the fenders back in a bit.
If I had 8" wide wheels in the right offset I could fit the 225(really like a 230, 15's front and rear without much work but a 225 slick needs 9" wide wheels to work the best, 205's need and 8" wheel.
These are shorter than stock tires by quite a bit as well.
