Catch can is in now.
Parts list:
D1 racing catch can
6- 1/2" hose clamps
25" of 5/8" power steering hose
2- 3/8 pipe thread 5/8 nipple fittings
1- 90* 5/8"-5/8" barbed fitting
1- straight 5/8"- 5/8" barbed fitting
Copper tube to fit inside the 5/8 fitting
Jb weld
Black permatex
2- Stainless steel scrubbers
A piece of 2"x10" piece of aluminum or other metal for mounting bracket
So- the hardest part was tapping the baby unknown threads of the stock can to 3/8 pipe thread, a local hardware store tapped our cans with the fittings installed for 22 bucks.
After that, we went home, we drilled numerous holes in a copper pipe that could fit in the fitting and bent it to turn the pipe into the can.
Then jb welded the copper pipe into the right fitting in the top of the can.
Take your stainless scrubber and open them up where there is a hole in the middle then put the copper pipe through the hole. We used two scrubbers per can.
Take your permatex and run a bead around the top of the can then place the top to the can, including the copper pipe and scrubbers into the can, put the 6 screws back and tighten down.
The can is finished- baffled- and ready to be installed.
Now, mark the holes where you need to drill in your 2x10 plate to mount to the can.
Drill the holes and mount to the can.
We used some old seatbelt to act as a isolator and keep the can from being scratched and rattled.
Attach the two screws to the can.
Remove the 13mm nut from the shock mount and mark the hole to drill, remove, drill, then mount it all up.
The can is in place and ready to go.
Take your pcv line, cut it in two where the plastic is smooth, basically right in the middle of the hose.
This side will now need to be boiled to let the plastic expand, take your straight 5/8" fitting and work it in the hose. It's very challenging but getting a couple barbed on is more than enough. After you run it under cool water it should form to the barb and it won't come off. Now take some of your power steering hose and put it over the other end of the barb, then measure the distance to the left side fitting on the can, cut, and put hose clamps on the two barbs.
Now, on the other side of the pcv hose, you will need to take a razor and remove the hose from the fitting going to the motor. The fitting is barbed and again, the plastic hose is form fitted to it. Cut it off and keep the fitting. Slide the power steering hose over.
Now, take the power steering hose and put it on the catch can, run the hose straight out, and cut it where the two hoses would intersect. Now insert your 90* fitting and put clamps on.
Guess what:
Your catch can system is finished.
