Thread Starter
#41
Thread Starter
#41
You have an aftermarket FMIC. That, in and of itself, will keep preserve the timing due to the cooler charge temps. This is factored into our MAP-based tune in the timing compensations. You can qualify it as a gain if you would like but I prefer to consider it a preservation of the original power. I've said this multiple times.
So again, post your datalog showing your throttle closures or at least try to comment on the one that I posted. Your load is going to have the same limits as stock because it's not a MAF-based tune and once you hit them your throttle will close to keep you from making more power. Go ahead, datalog it for yourself.
