Tackling this project now. Using hispirish methods.
Do I now cut off red plastic ends and splice them together? Any other tips greatly appreciated.
Here you go. This might help.
First, on the male connectors no grinding needed. Just use a pick to depress the locking tab and pull.
Then on the male connectors, grind those a bit on the side opposite of the little nub.
Insert those male pins (the ones that you removed by grinding) into the large Ford connectors. Slide the red locking tab on the Ford connector to the rear to expose more of the pin, then use needle nose pliers to pull it in and seat it. Once all 4 pins are inserted, slide the red locking tab forward.
The female sockets are much simpler. Just insert those into the smaller Ford connectors.
When you go to plug these into the car, you will need to make sure that the female sockets are given some forward pressure because they have some slop as you will see when you assemble them.
