I've done a ton of research (years), and got bitten by the carbon bug at 52,000 miles on my 2008 VW TSI.  The #2 intake port was so choked up with carbon that during a cold start, it couldn't get enough air to mix with the extra cold start fuel and it was misfiring.  VW didn't even attempt to clean it, it was so bad.  They replaced the cylinder head.  The one pic I saw in this thread of the FiST intake port was nothing to worry about.  Even port injected engines get a little buildup in spots.
That said, just a catch can isn't going to solve the GDI carbon issue.  There are a number of factors that affect the carbon buildup issue.  Fuel quality (top tier vs. cheapest gas around), amount of idling, how it's driven (stop and go vs. highway), amount of time it will be driven between startup and shutdown, oil quality, and even Ethanol has an effect on it.
PCV alone isn't the only contributor.  The very nature of how valve seals work contributes; a little oil ends up past the valve seals to lubricate the valve guides.  That oil ends up in the intake port.  In port injection, it gets washed in to the mixture and drawn in to the combustion chamber.  In a GDI engine, it sits and cakes in the intake ports and on valves.
EGR operation (in the case of variable valve timing like the FiST, they use cam timing for EGR instead of EGR valves) contributes to buildup.  This loops in the Ethanol effect.  Unburnt ethanol is a cleaner, but burnt ethanol is quite sooty.
Poor quality fuel contributes to increased carbon deposits not just because it's dirty, but the lack of additives contributes.
Idling a lot and constant stop and go contributes because things never get hot enough to burn off deposits as they build up.  Starting it, driving it a few miles to work, and shutting it down contributes the same way.
Avoiding getting bitten by GDI carbon issues is a cumulative thing.  Using a good quality oil with a good detergent pack and a low NOACK will help.  A catch can will help.  Avoiding other things I spoke of above will all help.  I have seen VW and Audi guys with meth injection that still get the buildup issues because the meth injection by itself won't fix all of the other problems that contribute to the problem.  Then I have a buddy at work with the same TSI engine in his MK IV GTI I had in my Jetta, and because he regularly tracks the car, at 120,000 miles he has zero carbon issues.
Here is the pic of my #2 intake port from my 2008 Jetta Wolfsburg 2.0 TSI right after the dealer pulled the intake manifold off:
