lorton, VA
Did some testing with my sync 3 radio yesterday..... I will need to do some digging around and reprogram the APIM on my Sync 3 APIM. My radio faceplate does not light up with the Sync 3 pluged in but does with the old Sync 2 pluged in. GPS is also innacurate at times and my clock resets to 1200 at times. I've read somewhere that the clock master has to be synched with the APIM when switching from Sync 2 to Sync 3. I probably need to pull the as built values from a 16+ that has the exact same options as my 15.
lorton, VA
Finally got everything working on my Sync 3 radio. There were a bunch of incorrect as built values the eBay seller didnt set properly for my car. Now the clock is accurate and GPS doesn't loose track of my location. My faceplate now lights up like its supposed to. This also got rid of 2 pesky APIM trouble codes.
Knoxville, TN
Installed about a month ago, forgot to post. Got a K&N CAI (63-2587). I absolutely love it. You can really hear the turbo spool up and the blow off valve much better, and the throttle response feels great now. Easy install too. Only problems I had were getting the intake snorkel off the stock air box, and getting the conical air filter to fit over the new intake pipe. Probably took about an hour to install, not bad at all. Definitely worth it.
haste
Eastern
View attachment 53134 View attachment 53135
Why are the pleats bent so badly on the new air filter? You may want to take a very close look at the creased areas to make sure the filtration media hasn't been compromised and allowing dirty air into your engine.
lorton, VA
Just copped a COBB tuner used for a steal. Should get to my place by Friday. Going straight to a COBB stage 1 ots map. Once I get my setup ready I can get a lifetime tuning deal from Purple Drank and really dial in the Fiesta.
Broken Arrow
More goodness to add to the radio... Just a little Forscan magic... Still gotta do the GPS antenna USB hub and power harness but Sync 3 is already 1000x better then Sync 2.
I did the same thing this weekend! Looks awesome. I also used forscan to disable my TPMS because my aftermarket wheels do not have sensors. I now have a light free dash :D
lorton, VA
Also got my rear seats unbolted from the car in prep of finishing up the load management system swap. still waiting on the seat mounting brackets but they should be arriving in the next day or so.
pixelzombie
Chicago, IL, USA
I also use the Cobb Stage 1 tune, so I'll be curious to hear your results with PD-Tuning.
lorton, VA
I'm actully getting my Mustang tuned with PD-Tuning. Going for 520HP on E85 by summer time. Aiming for loq 400's on 93 pump. Put a hole in the block from 28 psi boost so I had Engineered Motorsports hook me up with a built longblock.
Sam4
West Chester, PA, USA
Left it at home for a rental sprint up the Jersey TP. Passed a very clean (rust red?) didn't seem orange, lowered. He was trying to ignore the idiot in the Focus...sweet
lorton, VA
Finished my load management system install today. Totally worth the money to source all the parts. Not too bad to install everything. Seats are fairly easy to remove and reinstall.
Ontario, CA, USA
Took a leap of faith on tpms sensors on Amazon. Put them on when I installed my new wheels. The light was off for like 2 weeks didn’t need to program or anything. Yesteday I got a flashing tpms and then solid. Thinking one of them took a dump. I have the reset tool might try to reset. If no luck might just disable it with forescan. Update I follow the relearn procedure and with the tool it relearned all the new sensors and took about 1 minute lol.
