x37-47 / 2554-60 / C39 / ST280 - Small Turbo Comparison Thread
OffTheWall503
From my gathering:
Original Cyborg - 240 to 260 whp depending on tune/fuel
Pumaspeed X37 - 275 to 300+ whp depending on tune/fuel
Cyborg39 - TBD
Pumaspeed X47 - TBD
WeTheNorth
X-37 / ATP 2554 & 60 / Cyborg & C39 Turbo Comparison Thread
From my gathering:
Cyborg39 - no real defined results yet
[emoji457][emoji457]zing
All I would like to add is, those numbers are on ethanol ;-)
grnmachine02
I told myself this car wouldn't be a project, but I'm gonna go hybrid turbo in 2017.
frankiefiesta
From my gathering:
Cyborg39 - TBD
Pumaspeed X47 - TBD
Those numbers are fudged a little :)
I've never seen a cyborg over 250 that wasn't sourskittle
And I've never seen a x37 over 300. I don't count the car from South Africa
re-rx7
I agree with this. I'll dyno my cyborg soon. Should be at or near 250-265
x37 along with a mountune ic> for those like me that do not have access to good gas...220hp....same deal on e30 255hp. funny that it is easier to get e30 than 93 locally. ....not complaining just informing. boyracer
frankiefiesta
That intercooler is holding you back man. Get a better one and you'll see +25 hp
DHM1
From my gathering:
Cyborg39 - TBD
Pumaspeed X47 - TBD
From my gathering:
Pumaspeed X37 - 255 to 295whp depending on tune/fuel (never been chassis dynoed higher)
Cyborg39 - 255 to 270whp depending on tune/fuel. (Stock airbox and stock exhaust e30 only)
Thanks fellas. I think this info should be loaded up and highlighted in the first page of this thread.
Reading 2-3 pages is ok....spending your lunch break on the shitter reading this. Not so much.
Now you have a hemi...
Rhinopolis
I recently purchased a 2cd hand 2JR cowl intake and went for a "real" ride last night with outside ambient temps hovering in the mid 50's.
I know that hitting more boost doesn't necessarily mean that you are making more power, and prior to last night I had never boosted higher than 26.68 on my X37. Often, I would never hit as high as that.
1st off the 2JR is everything that everyone had said it would be regarding noise etc., and I like it...lol. 2cd, I was consistently hitting high 27's last night and my peak was 28.19...lol.
I am going to do a few logs this weekend and compare those to my best previous Virtual Dyno. I am also going to send my logs to Adam for review and any potentially necessary update.
Long story short, would the 2JR have anything to do with my car boosting higher than when I had the Cobb on there before?
Sourskittle
Def have your tuner check your logs. I had a friend that went from a stock air intake to a 2J intake and because the restriction reduction was so great, his car actually ended up breaking a piston. He saw another 2psi as well. It's a pretty real indicator of the air intakes being a restriction. When your using a 450hp turbo to make 350whp, it's not the end of the word. But when your using a 290whp turbo to try and make 291whp, the little things do add up. No one ever matches my numbers on the OG cyborg because they never ran the same setup as I did with a tuner that didn't have a vested interest in something else.
Skittle I pm'd you a few days ago. Or at least I used the chat function on Tapatalk
Siestarider
Based on my experiments with intakes, I believe the 2J is about reducing intake restriction and about pressurizing the intake system. Location at base of windshield is a high pressure location.
Stock intake horn is also in a high pressure location. Comparing stock to 2J it would all be about intake restriction. Compared to using a Mountune air box with lower hose connected to a fog light opening gives two high pressure locations for intake, which my Vdyno logs suggest adds a few hp at the big end by increasing "apparent" boost.
I believe seeing higher boost with 2J (and my Mountune variant) is about intake pressure being positive at the compressor.
Agree with SS, if you are going to edge of tuning, this has to be accounted for by the tune.
Rhinopolis
Thanks, guys! I was planning on sending logs to Adam this weekend, and I will check with him 1st to see if he wants to offer a different tune file and before we start tuning with the 2JR.
