- Member ID
- #2745
- Messages
- 665
- Likes
- 180
Thanks, guys! I was planning on sending logs to Adam this weekend, and I will check with him 1st to see if he wants to offer a different tune file and before we start tuning with the 2JR.
Def have your tuner check your logs. I had a friend that went from a stock air intake to a 2J intake and because the restriction reduction was so great, his car actually ended up breaking a piston. He saw another 2psi as well. It's a pretty real indicator of the air intakes being a restriction. When your using a 450hp turbo to make 350whp, it's not the end of the word. But when your using a 290whp turbo to try and make 291whp, the little things do add up. No one ever matches my numbers on the OG cyborg because they never ran the same setup as I did with a tuner that didn't have a vested interest in something else.
Based on my experiments with intakes, I believe the 2J is about reducing intake restriction and about pressurizing the intake system. Location at base of windshield is a high pressure location.
Stock intake horn is also in a high pressure location. Comparing stock to 2J it would all be about intake restriction. Compared to using a Mountune air box with lower hose connected to a fog light opening gives two high pressure locations for intake, which my Vdyno logs suggest adds a few hp at the big end by increasing "apparent" boost.
I believe seeing higher boost with 2J (and my Mountune variant) is about intake pressure being positive at the compressor.
Agree with SS, if you are going to edge of tuning, this has to be accounted for by the tune.
