Going to be tracking? If not, standard DOT4 fluid is fine. Otherwise you should think about going to a Motul600 or the like, even though the higher end fluids should be flushed more often...
It depends on your needs and driving style. I for example am not super aggressive on my brakes but Houston drivers leave a lot to be desired so when someone cuts you off which can happen often here you'll want to be ready. Also, I know I don't want to change fluid that often so I guess I'm looking for a good fluid that won't boil on me when I need it to perform, but doesn't need frequent bleeding.
Thanks guys. I haven't tracked the car yet and have big plans on doing it this summer. I think I'll look into the fluid before I start.
As far as a verdict on my brake setup here's what I can say. They work much differently than the OEM brakes. They have a ton of stopping power but it comes on in a different way. With the OEM brakes it feels like the car dives from light brake application. These brakes don't do that. It messed with me at first because it feels like they're not working as well. However it's much more linear and once you start pressing they start working. I'm on winter tires right now so my stopping ability was limited based on the tires. At about 30mph I slammed the brakes and got a quarter second of squeal followed by ABS. Later on the highway I responsibly reached the speed limit
and dropped down to around 40 mph as quickly as possible. Braking power came on smooth and car decelerated rapidly and felt very stable. Much strong than OEM. Can't wait to have my summer tires back.
I'm about to have to get my brakes done also and was planning a very similar set up as you. Is it unnecessary to get cro-treated rear brake disks?
I'd say no simply because my rears weren't really beat up that bad. They may not have even needed to be changed. The fronts looked like they went through a grinder. Someone correct me if I'm wrong but Cryo-Treatment improves durability, not performance.
