My point is absolutely valid as you are highly unlikely to find any wheel with enough offset and use an adapter and not have the scrub radius jacked up
To keep the stock scrub radius with just a 1" adapter you would need to find wheels with a +72.9 offset, with a 2 in adapter they would need to be +98.3mm when using a 7" wide wheel.
There might be some wheel one could dig up but none I have ever seen and I have had hundreds of sets of wheels on dozens of vehicles and do the research to make it right, always.
There are sometimes exceptions where you have to give up a bit to get what you need, I run 15x9 wheels, +35mm offset, my fronts require a 2mm spacer to clear the coilovers. My scrub radius is not perfect as the center of the wheels are 14.5mm off from the stock radius but close enough to easily be over come by the added track width and more sidewall support. I have a chart with every option and all the numbers laid out but it got stored away during our move with some other things I wish I could get to, I will find it one day I hope!
The main issue is the band aid approach, adapters are not allowed in many race sanctioning bodies but proper spacers are in all I know of, there is a reason for that.
