I have enjoyed working with Adam who has helped to perfect an E30 tune along with his upgraded WGA. I trust Adam, and if this is what he is promoting and believes in then I will gladly give him my business. I have been eyeing a turbo upgrade anyway.....
I am nervous about pulling the turbo for some reason, and is this a fairly straight forward process? I feel like I am mechanically inclined above a basic level, but "messing with the turbo" intimidates me for some reason.
What are the potential pitfalls that I might want to watch out for should I decide to tackle this on my own?
Also and with the Pumaspeed X-37 hybrid turbo setup, will an aft market DP improve peak power? I am running the stock DP right now, and I would purchase an aftermarket DP if it was recommended. If recommended, which specific DP should we go with?
Thank you!
Ryan
Thank you!
Ryan
Thank you for the kind words. It is really straight forward, even more when the turbo is a factory turbo that has been upgraded. Literally remove bolts until you get the unit you are replacing out, and stick the new one right in it's place. There is no modification needed, remove and install. Kind of like replacing batteries in your remote!
I recommend a DP with the X-37, it moves enough air to gain benefits from a catless or catted aftermarket downpipe. I can get you a deal on a X-37 and a Pumaspeed or MAP downpipe.
