Konig Hypergram
Chris G
San Diego
Good deal! I ended up going with those Gorilla lugs and they fit the Hypergrams perfectly. These wheels fit the car great, I don't even think pictures do them justice
Man, I can’t wait. I had wheels on the FiST quite some time ago, but went back to stock for numerous reasons. Can’t wait to see how they fit with my setup.
alexrex20
Spring
looks awesome. how are you liking the NeoGens? I'm running them on my Dekagrams and have no complaints at all
Charlotte, NC
Haven't been able to test them too extensively but so far so good! Going with the slightly wider 215, I haven't noticed any difference in traction compared to the stock Potenzas even though the Neo Gens are an "all season" tire.
And they've got a nice and aggressive look to them so they definitely pair well with aftermarket wheels
MagnetiseST
Dania Beach
I just posted a whole other thread about these *facepalm*
I am running 205/40/17 Indy 500s right now (and two new ones coming tomorrow). But the general consensus seems to be that 215/45/17 will rub based on width, I just want to fill the wheel well gap and lose the minor stretch, 205/45/17s will fit with a mild drop? I have Swift Spec R springs.
Lake Forest, CA, USA
Does anyone know if Konig ever did a run of these in 17x8 4x108 +40 in racing bronze? I swear I've seen pics of it on Fiestas but for sale nowhere. Maybe people with hub conversions...
Sent from my Pixel 3a using Tapatalk
Bay Area California
I know I’m reviving a very old thread, but can someone confirm the weight of these in the 17” size? Whoosh says they weigh 16.3 lbs while Tires.com has them at 19.36 lbs. I’m guessing Tires.com is the more accurate number, but can anyone confirm this?
MagnetiseST
Dania Beach
I don’t think that the potential 3lb variance makes much difference once you get into tire selection and how much those weigh based on brand / size. The wheels are light, they are in the 16-20lb range per wheel. Buy them.
Evo8
U.S. Marine Veteran
Charlotte
I can't confirm the exact weight but they are certainly a few pounds less than the factory wheels. I finally pulled the trigger on a set and put them on about 2 weeks ago. I'd lean towards the 16lbs - get them, you'll be happy.
Hypergrams are heavier than Dekagrams. 16x8 Dekagrams came in at just under 15lbs . Rota Titans in 17x8 were just over 17 pounds. They are lighter than Hypergrams in 17 inch.
Suwanee
I have a set of hypergrams 17x8 on stock springs and shocks. they do not rub. lowering it any at all will, i'm pretty positive, result in rubbing when the wheel is turned. rubbing in the rear also if dropped much if any from what i can see. my fender liners are half gone already from autocross wheels, but you'll be wanting 16's at most, and even then if you're dropped more than an inch you're looking at a camber kit or something.
Bay Area California
What tire and size are you using?
Bay Area California
What tire? They all differ in size slightly. Also, my understanding is that the Swift spring and B6 combo don’t lower the car *that* much. I’m pretty well versed in cars and modifying them, but I’m very new to the FiST. I just had mine delivered last Thursday!
What club are you autoxing with? SCCA?
Suwanee
just street tires, general as07's. its really close in the rear now.
SCCA, but it's now been a minute since i've been. college aged kids and college bills have put a stop to fun for a while.
Your factory springs must be sagging horribly then.
Because I've had 42ET 17x8 TD Pro Race 1.2s with 215/40-17 RS-RRs on them, as well as my current 40ET 17x8 KE Motorsport T12s with WIDE treaded, and square shouldered 215/40-17 Yoks on them on the factory suspension, and they never EVER rubbed at all, even in the worst case scenarios, (and not even on the Rally Armor front mud flap hardware like my 40ET 16x8 Dekagrams did under hard braking, and on sharp turns and bumps, with 205/50-16 Neo gens on them).
