Has anyone tried the Torque Solution Billet RMM?
Toledo
mine failed before break in-returned immediately and bought the cpe, no regrets. It had excessive play and would bounce back and forth, I have a video of it somewhere, you could rock the engine back and forth-the clearance between the bushing sleeve and bolt shaft was too large. manufacturer defect they had told me.
Well thanks to all for feedback! Looks I am now leaning towards the Cobb. I want to not always have to granny shift.
danbfree
Tigard, Oregon, USA
Just to raise this from the dead, I got a Torque Solutions about 5 weeks ago and absolutely love it! There may have been a bad batch way back initially as a defect was mentioned earlier, or maybe it can't handle the power of a built FoST but the dual 75a bushings seems like the perfect daily/performance balance... There is only so much that an RMM can do anyway, I don't really see how anything stiffer than this will provide better results on a stock turbo and not just add more vibes... At idle it is literally barely noticeable at all, in fact I cancelled my tune update to raise the idle speed it's that much unneeded. It does have a bit of a lumpy idle if stopped on a upward incline and some minor vibes the first couple of seconds while taking off from a stop. I torqued mine down to 50ft/lbs and *most importantly* have noticed zero difference in feel from day 1 to 5 weeks and I'm a good 3000 miles in, so seems like the bushings are extremely high quality. Torque Solutions is not a knockoff brand, they make all kinds of stuff for other performance cars and seem quite reputable... Wheel hop is pretty much gone and now my tires actually spin like they should but also hook up much better too with my strong Stratified tune. I got mine off eBay on one of those coupon days where you get $15 or 20% of any one item so I only paid $99 and seems like the perfect balance for a tiny bit stiffer than the AWR 70a... Just my $.02!
Stockton
Do you still recommend the Torque solutions?
XanRules
Portland
Dan has long since sold the car and left the forum - the post you are replying to is more than six years old - but, while he was a hell of a nice guy, he was often bending over backwards to justify his purchases and got a lot of stuff wrong as a result (don't worry, he would say the same about me, see our arguments about headlights in the lighting subforum ;)). Torque Solutions is indeed a knockoff brand, they've long had a reputation as such in the WRX world, where they started out. While to some extent a part like a motor mount's design is dictated by its function, the TS RMM is pretty much identical to the Cobb from a design perspective. Just spend the extra twenty bucks for the Cobb.
Stockton
Thank you for the reply, I figured I’d ask on an old forum and hoped to get info and you did just that! I appreciate you friend.
XanRules
Portland
Cheers. Dan, in case you're still lurking, no disrespect intended, buddy, I realize my post was WAY cattier than intended and I apologize lmao
