Well, I have the aem kit using the mid sized 500 cc nozzle on my gtx2860. I drilled a hole in the bottom of the washer reservoir and epoxied the supplied tank fitting to it. Did the same with the level sensor a few inches higher. The pump is attached to the frame under the air cleaner. Nozzle is screwed into the plastic cold pipe half a foot or so before the t-body. Controller is zip tied by the battery wrapped in a Ziploc bags lol. Only ran the led inside the car and mounted it under the cluster. It's not the most professional way, but it's solid.
