Fiesta x37 build
agangel
san diego
Thread Starter #62
They dont make a Rear view mirror Mount for these? I got one with my Valentine 1 in my Fist and its barely noticeable until it gets hit with a Signal and goes off.
I like the way I mounted it to the dash. It's attached with a magnet so if I get pulled over I just remove it and toss it under the seat(I did this last time I had to deal with a cop, they give shit for those most the time). They probably make a rear mirror mount but it works well the way it is and I don't think it looks bad....
Saint Pauly
#63
Here is mine* I've been pulled over multiple times....Cops never hassled me once...Anywhere. 20240727_122730.jpg
agangel
san diego
Thread Starter #64
Here is mine* I've been pulled over multiple times....Cops never hassled me once...Anywhere. View attachment 63119
I got hassled once then I told him I got it from Costco (which I didn't). I just want to look as innocent as possible. But yes rear view mount is better. Your's looks dope. Maybe a future mod for me.
agangel
san diego
Thread Starter #65
Hey do have instructions on how you routed and connected the wiring and which mount you got? The more I look at yours the more I like it.
agangel
san diego
Thread Starter #68
Just finished a midnight run of Palomar Mountain South Grade. No one was on the road and it had a thick layer of fog. I've got to say the NeoGen tires totally fit the bill for me. They drove fine for a budget set. The NeoGens are kind of comparable to the indie 500 in my mind. It was fun, the car was a blast. The X37 pulled like a train and whistled like a kettle on demand. She cornered like a dream with little effort. The Godspeed coilovers were tight and predictable, the perfect height as I went over some cattle guards at a good amount of speed and the whoosh track bar didn't scrape anything. Ebay radiator is still kicking, temps didn't got over 190F. Adams tune pulled some boost to keep her safe as I hit altitude.
Saint Pauly
#69
Just finished a midnight run of Palomar Mountain South Grade. No one was on the road and it had a thick layer of fog on it. I've got to say the NeoGen tires totally fit the bill for me. They drove fine for a budget set. The NeoGens are kind of comparable to the indie 500 in my mind. It was fun, the car was a blast. The X37 pulled like a train and whistled like a kettle on demand. She cornered like a dream with little effort. The Godspeed coilovers were tight and predictable, the perfect height as I went over some cattle guards at a good amount of speed and the whoosh track bar didn't scrape anything. Ebay radiator is still kicking, temps didn't got over 190F. Adams tune pulled some boost to keep her safe as I hit altitude.
If you can ever find them the Michelin pilot sport 5s in the stock size are the best tire for all warm weather conditions i've encountered* I got mine just by luck last summer at Sams Club of the weirdest places. Enjoy them!
agangel
san diego
Thread Starter #71
Palomar Mountain – South Grade (Hard Section) write up
The technical hard section runs several miles with tightly stacked corners, short straights, elevation change, and limited sightlines. It’s moderate high difficulty due to corner density and constant transitions, rewarding continuity and anticipation over peak speed.
Gear choice:
Staying in 2nd gear minimized shifts and heavy braking, kept the drivetrain loaded, and reduced disruption between closely spaced corners. Short straights didn’t justify an upshift because any small gain would immediately require harder braking into the next turn.
South Grade favors a single-gear, low-transition approach; 2nd gear aligns well with the road’s demands without chasing upshifts.
Fiesta ST — 2nd gear mechanical range
(US-spec gearing, 2nd = 2.048, final = 3.824, 205/40R17)
Usable low end: ~20–25 mph (low-mid RPM, smooth response)
Core usable band: ~30–50 mph (where it feels strongest and most controllable)
Near shift point: ~55–58 mph (around a conservative ~6500 rpm shift light)
Absolute top (rev-limiter dependent): ~60–64 mph (if revved higher)
agangel
san diego
Thread Starter #72
Coil Pack Swap - Budget Option
I swapped in these coil packs mainly to see if I could reduce negative ignition corrections and improve spark consistency. Not chasing power, just smoother, more reliable behavior on a tuned car.
Link :
https://a.co/d/gEdq9R2
Install:
Direct plug-and-play. Easy swap, no fitment issues.
Observations:
Idle feels smooth and stable
Fewer negative corrections under load (based on Cobb/logs)
No new issues, misfires, or CELs
No noticeable power gain, just better consistency
agangel
san diego
Thread Starter #73
Fiesta ST Smog Experience (modded but passed)
Just went through smog and figured I’d share what worked.
Usually run E blend, but switched for smog
What I did:
Switched to Stage 0 / stock map
Stayed out of boost drove it until all readiness monitors set
Took a couple drive cycles + cooldown periods
Issues:
Some monitors took a while (EVAP was the slowest)
At first I wasn’t “ready” even after driving a decent amount
Intake tube isn’t stock, and the guy actually questioned me about it but still passed. I'm going to switch to the stock intake tubing. It's not worth the stress.
If on a stock tune and factory snail, why would a lower (like ~E20 total) E blend negatively effect the smog test?
NOx way too high?
Something else?
rallytaff
Los Angeles
#75
What I did:
Issues:
Hopefully if either Hilton or Bianco get in, they will eliminate CARB, which is already broke and smog checks.
agangel
san diego
Thread Starter #76
NOx way too high?
Something else?
indirectly—by pushing fuel trims higher and delaying readiness monitors (especially catalyst/EVAP).
If monitors aren’t ready, you fail. It’s not due to NOx or checksums.
