I have over 1200 datalog pulls
I've tried low timing, high boost. High timing, low boost. But so far, what makes the best power for me is high boost and high timing, lol. 24psi at redline with 17.5-18degrees of timing above 6,000rpm works the best, lol.
Iso I agree. That iffered Temp or whatever is very pointless for me. And Russ's big turbo numbers don't tell us much because those big compressors don't get in the same ball park as the stock turbo at the same boost levels. Luckly, Russ also has stock turbo logs too with the big cooler.
Before I reallized that the car had no REAL compressor outlet temp sensor, I was very confused in what I was seeing in logs, lol. 350+ degrees was not un-common, but thats because if I was running the stock turbo, that's close to what they would have been. A fat compressor wheel helps a lot with that though
