I talked to the race shop at MMP yesterday, David there was very helpful to say the least
No heat issues with the Fiesta ST so far but they are stock.
Major heat issues with the Focus ST so several steps taken to cure them.
I mentioned my idea of opening up more of the top grill by drilling out the holes looked at using a dremel to clean them up, very time consuming so decided to sand them down from the back. That is exactly what they did on the Focus.
I am considering removing the water to oil cooler, it will allow the radiator to do a bit more for cooling the engine, and installing a thermostat controlled sandwhich plate under the oil filter, I have a Mocal here I can use.
I will install a much larger oil filter as well, more oil, more surface area to help cool, more filtering.
