Yes but you can't hear turbo barking from stock turbo?
You mean Turkey mode?
I am by far no expert in turbos by any means, but isn't that merely the air not venting to athmosphere? I thought that noise was when the air is pressed back into the system a little bit causing the sound.
Some people say "TSU-TSU-TSU". Some people say "bark". Some people also say "Gobble" or "Turkey mode".
When you have a BOV that is set to vent then you get the "PSSHHH!" sound instead. I know that there are some BOVs that are mechanical and you can manually set them at a percentage of how much they vent.
Seeing as you have an upgraded turbo (This is a garret right?) then this is merely the byproduct of you having a nice and beefy turbo compared to our stock little "bagel bite" sized snail that a stock ST has.
If I am wrong, then by all means tell me. But from what I heard in the video and from what you are asking, I assume that this is the case.
EDIT: The reason you can't hear it on the stock turbo is because it's tiny and the stock BOV thing vents enough that you can barely hear a small PSHH instead of the bark.
The reason I call it Turkey mode is that if you have a big enough turbo and enough boost, it seriously sounds like a turkey gobble.
