I just received my S284 kit on Thursday from Whoosh and I've reached the part where I need to plum all of the boost/vacuum lines. The kit didn't come with any instructions and all I can find online are walkthroughs of the standard S280 install which uses an adapter to fit the stock BPV.
On the standard kit, the three lines that come off of the solenoid on the turbo go to the BPV adapter, wastegate, and turbine housing. The S284 kit comes with a turbosmart bpv that uses a boost reference adapter which is installed on the manifold. If the S284 BPV uses the boost reference adapter, then where does the BPV line from the solenoid go? Also, there is an additional plug for a vacuum line on the turbo intake elbow. What do I plug in there?
Thanks for the help.
