When I got my first turbosmart dual port, outside of the connector was ambidextrous but it had an insert that prevented you from inserting the connector backwards. When I switched to the plumb-back, the plumb-back did not have the insert and I plugged the DV in backwards, cracking the plug that goes into the DV. It still works, but my obsessive brain knows theres cracked plastic down there... so I am going to have to fix it because I obsess about stuff like that.
Does anyone know if I can just order the connector part, crack apart the old one and insert the pigtails into a new connector, or anything like that? I haven't had an opportunity to get a good look at it, and Ford didn't list the plug as a standalone part when I asked at the parts counter.
