VirtualRonin
Military Veteran
Ajo, AZ
How do you like it? How ate the intake temps?
The intake air temps are at ambient or within 1 degree (driving at speed). Of course temps rise at a standstill but come back down when driving, as one would expect. It's pretty impressive! I'm enjoying the extra intake noise and I can hear my bypass valve (TurboSmart Plumb Back) too. It's not as loud as a Boomba spacer or TurboSmart Dual Port BOV so it's about perfect.
The picture below is from my drive to work this morning. Ambient temp was 68 degrees, speed was around 55mph. Don't mind the AFR, looks like I was off the gas when I snapped the pic.
Yorktown
I would kill for ambient temps like that, at 0645 it’s already over 80 and afternoons are 100 or slightly less. Which means I try to stay out of boost with slightly higher bats. Although the whoosh V3 and the heat reflecting tape do a great job of keeping temps from sky rocketing
Bravoalpha!
Orlando, FL, USA
Installed red tail light tint from premium auto styling today! Didn't come out perfect but I still think it looks a lot better.. and for only $15 why not?
Before
After
doesnt this make your reverse light and turn signal lights both red? I loved the look of this one but went with the red one that left the colors on the bottom..
Highland
I honestly haven't looked at them yet with the lights actually on but you're probably right.. not too worried about it though
JDG
Conshohocken, PA
Before
After
I attempted this install when I first got the car and failed miserably. I got so freaking frustrated. I have so much more respect for the guys that install wraps and clear bras and such. I ended up just swapping to the standard fiesta tail lights for a similar, less busy look.
Highland
YES those look much better I just went for the cheaper option for now ;)
I just posted a video on youtube of the install if anyone wants to try it (only $15)
View: https://youtu.be/wZNeSBY2YsM
brbauer2
St. Charles
I put the things I've done to my FiST to use today [emoji41]
Just happened to drive past a buddy that has a big turbo FoST on my commute home. I slowed up a bit so he could catch up. I knew there would be several prime opportunities to get pulls in before we would need to separate.
[emoji2510][emoji535][emoji41]
Sent from my OnePlus 6T using Tapatalk
