No problem and good luck! The Mountune directions for drilling a small hole into the silcone elbow are extremely vague. This is for the compressor inlet elbow (the bigger one). I did mine on jack stands as well, no issues with room. I dropped the stocker out the bottom, removed the the manifold through the top with the wiper cowling removed. Assemble your new turbo and manifold together off the car. Tighten the adaptwr to the manifold with the turbo clamped but leave the clanp loose. Drop the assembly in through the top, snug your bolts then adjust the position of the turbo THEN tighten your clamp. This is what had me screamibg, cursing, bleeding and flustrated lol. You can email me at
[email protected] if you need pointers during your install as this is all painfully fresh in my mind still. I can help as much as I can.
