So even with just a canned Stratified tune and mild intake mods, traction and wheel hop is definitely an issue, even when with the improved late builds RMM, I'm already into the mid power band I can see the excellent Stratified TC kicking in a bit on WOT... I have no plans for turbo upgrades, just trying to get the car dialed in a bit... I installed a short shift kit the other night, absolutely must have, for the precision improvement alone, I have no idea why Ford didn't just use a better linkage mounting point, but I have a Torque Solution 75a RMM going in tomorrow. So we will see how things are improved after that, I like the 75a in theory as it's a bit stiffer than Cobb but not crazy stiff 88a like some of the others are...
SO, I'm looking at inexpensive solutions to help further, I'm sure the RMM will help some with traction of course but also want to address torque steer. There is the Pierce brace for $90, but also found this Traction Bar that doesn't cost much more but seems to be a little beefier... With a '17 I'm happy with the thicker rear torsion beam and looking to do Eibach springs in the future for looks, better center of gravity and the progressive rate to help with the little road imperfections, etc., but really beyond this I don't expect to mod much more... So, best bet for torque steer and traction? I'm hoping just a single item like I mention above will do the trick but looking for feedback from what you guys have found works well. TIA!
