Got mine wired up this morning. Huge hats off to [MENTION=4498]OffTheWall503[/MENTION] for his write up - probably wouldn't have completed this the right way without that.
I did run across a couple things that appeared to be slightly different between my car and [MENTION=4498]OffTheWall503[/MENTION]'s car.
1. My wires were colored the same as the EDM vs. USDM diagram (below) on the driver side but not on the passenger side. No idea why that is but everything appears to be working correctly.
2. My light harnesses were slightly different looking than the ones on the write up. The blocking plates were white, not black, and easily came out of the bottom without taking the whole harness apart. Again, a few pics below...
Harness from the back:
Blocking plate piece removed:
Blocker removed from harness:
From a removal of the blocker and moving the wire standpoint, everything is the same. Here are a few finished shots of my lights and the LEDs. I will be using Philips Diamond Vision halogen bulbs for the time being.
Hopefully this helps some of us that have 2014 or 2015 models vs. 2016.
