BoostBumps
Arizona
Not concerned with sucking up water with that extension?
Not at all concerned...
Given the airflow path it takes, the filter will never see anything of significance with respect to water as the inner stock snorkel section enters the airbox well below the actual filter...
CanadianGuy
Southern Ontario
But what about snow? I know it may not be a problem for you per say but it is worth noting i think.
BoostBumps
Arizona
The snorkel opening is ~22" above the ground so I suppose if the snow is ~2 feet deep or your grill is packed with snow then that could be a problem....Also driving through deep puddles >2 feet deep wouldn't be advised either.... ;)
