koozy's ST
TDavis
Columbia
I've never found the plate to not be "solid" when mounted with only two screws...
The Sewers
I was able to lift the plate off the rubber bumpers and that to me was not a solid mount. I just prefer 4 bolts/screws to be used to securely mount the plate.
Good info...I will have to do that as soon as I get a chance to run out to the auto parts store. [wrenchin]
p.s. any particular brand or would it be a universal fit?
koozy
koozy
Los Angeles, CA, USA
Thread Starter #344
I got whatever they had, the main thing I needed was the plastic inserts. Kit was $1.99
koozy
koozy
Thread Starter #345
Update on the license plate mount. I added some 3/16” rubber spacers on the back of the plate before the plate mounts to car, this helps aesthetically, keeps the back cleaner, and keeps the plate and any plate frames away from the paint at the edges that could potentially mar it.
I also found all of the parts needed at Home Depot which are better quality.
Spacers
Parts at Home Depot in the metal misc parts drawers.
koozy
koozy
Thread Starter #349
Just finished making this DHM turbo manifold shield and will be up for sale soon, waiting on a few things to complete the kit.
Perfblue15
Canyon country
What's the price point going to be on this ? I'm pretty sure I want it. [emoji12]
koozy
koozy
Thread Starter #351
At least a Ben Franklin, which I feel is fair for the time I've put into sourcing the parts and time put into making it. This isn't a massed produced part, it's hand made and I'm not planning on mass producing these, this one may be the one and only one I will ever offer for sale, which would save at least one person from having to reinvent the wheel. I had enough material left over to make one, so why not. Much like the oil drain tube I made for myself and a few others that needed one, it's really a labor of love. Like the oil drain tube, the heat shield will be complete with all necessary parts to secure it to the manifold.
koozy
koozy
Thread Starter #353
Perfblue15
Canyon country
Haha I'm definitely ok with the price. Let me clear it with my old lady. Thanks again for making this stuff for those of us that can't fabricate to save our lives.
East los angeles
yeah, Anthony told me where and who his kit went to. that new shiny oil drain tube in your kit was made by me [thumb]
Here's a how-to for the DHM turbo kit install that may be useful to you or offer some insight.
https://www.fiestastforum.com/threads/8141-DHM-Turbo-Kit-Installation-Notes-Guide
Thanks so much :p yeah love that fab work on that drain tube.[thumb] im going to give it a go on the install maybe next month. thanks for the link on the install appreciat it
koozy
koozy
Thread Starter #356
I think I caught this one in time and saved my ~$70 for a new negative BMS cable. I had the battery out doing some work. While things are out I often take advantage to clean and check things out and noticed that the BMS (battery management system) enclosure was being compromised. Doesn't look like any battery acid/corrosion made it in to the housing to do some damage, so I removed the cable from the car to thoroughly clean it up. I used toothbrush with Permatex battery terminal cleaner to neutralize any possible acid contamination. Once it was clean and dry I epoxied the cavity. Cleaned up the positive side too as precautionary. If corrosion/acid compromise the BMS or inline fuse weird electrical symptoms can occur.
Cavity
Cleaned and epoxy filled.
koozy
koozy
Thread Starter #358
Got tired of the dingy colored and deposited coolant reservoir, so got a new one. I preferred the OE see through design with the built-in baffles/filter and at ~$30 I consider it a disposable item.
Still digging that OE sleeper look packing a DHM 360R Garrett GTX 2860R Gen 2 turbo kit with single port Auxfuel [deviltail]
jeff
Evans
Dude that looks dope! More pics please! Product link!!!!!
EDIT
Just read through your build thread. Very nice A+ job.
