Wrench light no cruise control
Tim2525
Danbury
Hi everyone. I would really appreciate any insight into what the issue could be. Thanks in advance. Here are the details:
2014 Fiesta ST
The wrench light comes on either when I brake or hit the clutch only when stopping/slowing down.
When the wrench light comes on, cruise control does not work
It doesn’t come on if I’m driving slowly (in a parking lot for example) and then brake/hit the clutch
Wrench light is not always on when the car is started - it seems to be triggered by something
It is not generating any codes
Tried to reset it using the directions from the manual multiple times
JasonHaven
Washington
Likely the brake pedal sensor, I had to deal with this last year. A few on here have had it. Unfortunately, dealers won't believe it until they see the light themselves, so be prepared to get a run around.
T
Tim2525
Danbury
Found what was wrong. Up above the brake pedal there are 2 switches. One is the brake light switch (black) and the other is the cruise control switch (blue and white). The cruise control switch was loose and not locked in place. I messed with it and it locked into place and now the wrench light does not come on when I push the brake.
