Hey guys. Please help. Want to remove my wing risers. Need help with part numbers for the screws and bolts as I dont have the originals. I found part numbers but the sizes are different.
I am not 100% certain however, with the bolts/screws you have you should be able to match the shank size and thread pitch.
Again with the bolts/screws you have, just subtract the amount of the wing spacers and you should have the length.
A hardware store clerk may be able to help you.
Just to be clear you're looking for the hardware that fixes the wing to the hatch? If I get the chance I can make a run to the hardware store and let you know. May not be today though. Will follow up
Removing wing risers can be a bit tricky without the right screws and bolts. While you've found a part, it's essential to make sure it's the correct one for your specific make and model. For the right screws and bolts, you might want to give https://www.scrooz.com.au/ a shot. They have a great selection of fasteners and automotive hardware. It's a good place to look for the parts you need to safely and securely remove those wing risers.
