I too have manually bled many ABS systems including my 2011 Fiesta SES and my current 2014 FiST.
The darn things will almost bleed themselves.
I don't know what trouble you are having but I would be happy to help you.
I posted a procedure here some place and I will look for it.
If you like, PM and I will give you my number and talk you through it.
Dave
Not sure about the Ford tool as the Shop manual say only to have it serviced at a Ford dealer and nothing of much use on how and what it does but being it is part of the TV and esc who knows for sure what worked on the old Tbird or Probe may not work on this wild weasel ...
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But when I swapped brake lines and rebled the brakes it went just like any other car though I made sure to keep the upper res full of fluid as I could not see the main fluid res very well
Hmmmm? Well, that sure sounds strange. I've manually bled more than a few ABS systems (including Ford) without a "special" tool. That said, I HAVE had problems with the front/rear proportionoing valve sticking and leaving air in the rear. You know the brake pressure is biased heavily to the front, so the valve to the rear doesn't open unless there is significant pressure in the system. If it was empty, the valve is likely stuck. You will need to whack it with a small tool or screwdriver handle while poking the brake pedal HARD. When it frees up, you can bleed the rest of the system.
I would expect the Ford tool to only be required if following the actual Ford procedure to eliminate any "extra" steps.
Unless you drained the system to the level of allowing air in there should be no air in the module, just the old fluid.
I do not recall any info on this ABS about where the fluid goes that is used when engaging the system, let off the brakes, returns to the unit or goes around it and more comes in from the reservoir. Engaging the ABS may or may not be an effective way to get the old fluid and or air out of it.
I wish I had a better answer for that to help you, perhaps the Ford rep here can help find the answer unless a member knows how it is setup on this car or ABS in general.
Keep in mind when I got home the day that I tracked my car my whole front brake system was bled dry. No Fluid in the top reservoir, master cylinder, and front calipers. There was probably none in the ABS unit as well since I frantically hit the brake coming into Turn 1 at Thunderhill. So I bled my system 3 times. I used the traditional 2 personal method, i.e. person in the car pumps up the brake 5-6 times until it becomes stiff, they maintain pressure, I crack open the bleeder, the pedal travels to the floor and is held there, the bleeder is then closed. Repeat 3-5 times until only fluid is expelled from the bleeder without evidence of air. I hit all the calipers with a rubber mallet to try to knock out any hidden air along the passages within the calipers. I can 100% say that the non ABS lines have no air. While the car is off, the pedal is hard as a rock. It isn't until the car is turned on that the brake pedal sinks to the floor and it has to be pumped 2-3 times before it becomes stiff again. I figure when the car is cycled on that the some of the brake passages to the ABS system open up. So with that in mind I rebled the system while the car was on. Yes the system did get better but instead of the pedal maintaining pressure after 2-3 pumps it takes 1-2 pumps. I bled the system starting with the RR, moving to RL, then FR, and finally FL. The car stops now, but not on the first pump, I have to pump once more to gain pressure, and on the second pump I have a real pedal feel.
Since I bled the system while the car was off and on, I don't know what else to do other than take it to the dealer (I made an appointment for Saturday. $110 for the job). It is raining all day today and tomorrow so I was thinking about taking the car out behind my house and doing several stops going from 30-0 in order to engage the ABS and going for a rebleed once or twice more. I checked the ABS unit and there are no bleeder valves on it like there was on my old Acura.
Do you guys have any recommendations/ideas? Errors to my methods?
Thanks
Jose
