First things first, let's start with some things about it.
Build quality: Awesome
Fitment: Awesome
Price: Awesome
Company you're buying it from: Awesome
And now the cons.
No whoosh branding on it, That's the fast and furious in me coming out. For real the only con i can think of. Except for not owning it, that would be a massive con.
Compared to the stock hot side pipe:
Quality of the material used is top notch, not even a hint of a crush to the bend, and the inside of the pipe is smooth smooth smooth
Install of this can literally be done by anyone with a jack and some stands or a set of ramps. Tools needed - flat head screw driver.
Total time to install 10 min tops.
Fitment is perfect, and goes into the boost hoses further than the stock one did, speaking of boost hoses, you should get the Whoosh ones and install this at the same time. (read a review of those HERE)
After the install i drove to an undisclosed "test track" and did a dead stop, 2nd gear rolling and 3rd gear rolling pull.
Going totally off of feel, With the only other mods being Whoosh boost hoses, COBB drop in filter and RMM it feels like there's less lag, boost hits faster, and some spooling noises are a little more noticeable.
Conclusion -
Should you buy it: Yes
Will you see a ton of gains with this being your only mod: No
Get rid of that silly baffled hot side pipe and treat yourself to a great part for a great price
If that's your plan click HERE to order!
Fitment: Awesome
Price: Awesome
And now the cons.
![](https://image.ibb.co/fRFLFn/image2.jpg)
![](https://image.ibb.co/mKtkgS/image4.jpg)
![](https://image.ibb.co/kf7p87/image3.jpg)
![](https://image.ibb.co/nPhd1S/image1.jpg)
![](https://image.ibb.co/i4R5gS/image6.jpg)
![](https://image.ibb.co/dmg5gS/image7.jpg)
![](https://image.ibb.co/cc1hT7/image8.jpg)
Conclusion -
