They spin at the same time if you're in a straight line.
Hi fellow Alex. This is also my first post on this forum although I've lurked for a while.
This is not entirely true - rarely true, I should say. Very rarely. Here is why:
Horsepower will choose the path of least resistance. If resistance is the same from left to right, it will spin both of them.
This is true. Whichever wheel has the LEAST traction will spin. This is why open diffs suck. The amount of traction between both wheels has to be EXACTLY the same for both to spin and this is very rarely seen in nature. Just the weight difference between each corner will be enough to upset this balance for one wheel to slip first, and then you're doing the "one tire fire" - try it some time. Do a burnout. You won't leave two stripes. You'll leave one. Because as soon as one wheel slips just a bit, that's your path of least resistance and all the power goes there.
Having a driver with no passenger will create enough difference. Having a weight difference between passenger and driver, will do it too. Having the car on a slight slope - same thing (most roads are banked so rain will drain off the side, even if the road is "perfectly level" by every other measure). I'm also fairly certain that if you corner balance our cars in stock form with nobody inside there will be a weight difference between the front wheels just because the battery is one one side and so forth.
Now add the fact that the road contains variable amounts of loose dirt/sand on top and pebbles every few square feet, tires wear unevenly, and a dozen other random variables and it's easy to see why open diffs leave one stripe 99% of the time when you punch it. Due to the mechanical differences in the trans-axle, one tire may break loose more often than another - difference in half-shaft length, internal mechanics of differential, condition of wheel bearings, etc. But it isn't ALWAYS the left or the right, that depends more on the balance of available traction at that moment, between those two contact patches.
I won't even mention one wheel being in a puddle, or on a road marking - that's just too obvious. Oops, I guess I just mentioned it
You're thinking too hard as far as rotation. Just do a diagonal rotation then a front-rear rotation and then diagonal, and so on.
Agree 100%, just rotate the suckers and call it a day.
