What should I be monitoring or looking out for in datalogs?
Houston
Recently went from stock to the stage 2 93 ots tune, and did some data logging, and had some questions on what to monitor.
During WOT the AFR was between 11.61 and 12.64, that looked good.
Octane Adjustment was at -1 the whole time, seems good.
Ignition correction varied from 0 all the way to 5.8 a bit in third.
Temps seemed fine, it's still hot as balls here in Houston, but the intercooler was cooling the incoming are up to 20 degrees.
Is there any other things and parameters I should look at to make sure everything is running fine.
