Sioux Falls, SD, USA
Its a shitty deal. I watched it happen through the window. Hopefully the B-pillar isn't damaged and its just a couple new doors to repair.
I am 45 years old and have never had to file an insurance claim or been in an accident etc so I have been cautious and smart, but mostly lucky.
Just glad it wasn't 30 seconds later or I would have been walking out the door and this clown would have ran me over.
Dallas, OR, USA
Just watched some tweaker snow plow guy blast the shit out of my hot rod in the gas station parking lot.
Know exactly how you feel, didn't even make my first payment before it was going to the body shop.
Hawthorne, NJ, USA
Finally found a set of recaros that were in a short driving distance. Just installed the fronts today and will install the backs once it's a little warmer outside. Thankfully came with a 12-volt adapter for the heated seats so that is really nice to have in the winter. Can't believe how much better the interior is with these installed.
Western NY
Vancouver
Installed some bilstein b6's up front with new strut mounts and strut bearings. The bearings were definitely toast. Then I went to play in the snow again.
Vancouver
Ouch sorry about that. It doesn't look too bad tbh. 2 new doors for sure as those doors look like they're beyond repair as the door beams are probably bent, which are irreparable. Rear door needs new door hinges, and the b-pillar might need a tiny pull, but maybe not because you're front door still lines up pretty good on the top and with the fender. Front door needs some new parts such as door handle carrier, door latch mechanism, and a new belt molding, just looking at the pictures. Everything else, just transfers over. Probably needs more parts after they tear it down. Blend the quarter panel and fender. Make sure they do some freebie dents on the qp and fender as they'll be painting those anyways, if you got any.
South El Monte, CA, USA
Installed vdyno and did a comparison of power output with and without an exhaust silencer in a 2.75" Tsudo catback which I'm not the greatest fan of lol. Datalog with silencer installed accidentally began at 3500 rpm so peak torque may be a wee bit higher in that run but it shows the 11 whp loss up top. Both runs were made within an hour of each other and on the exact same stretch of road. Also SAE corrected and as accurate as I could make them. The only stock exhaust datalog was taken at 90 degrees fahrenheit in summer so I couldn't add that for an accurate comparison. Only other mods are a glorious Dizzy Stage 1 tune with colder plugs and a Ramair filter. Cheers
Temp: 60 degrees Fahrenheit
Gear: 3rd
Altitude: 49 feet above sea level
I'm gonna be trading my stock exhaust for a tsudo one. wondering why you don't like yours and what was it about it that made you buy it in the first place. I haven't read or heard anything about this brand of exhausts. Thank you in advance for your reply.
