Mikey456
[thumb] YES, I am still on the factory suspension, and those were one of the first things to go on this car for me, right after the symposer delete and engine heat retainer (cover)! [wink]
Is it easy to remove? Looks like one bolt holding it on. Do u need a spacer when putting the bolt back in without it? Have not seen much on the forum about it.
Erick_V
You only need to remove the nut. I believe the threaded portion is in the weight itself, you remove the nut and it's free. You don't need to do anything else
DangerMouse
Got bored and I've been wanting a finishing piece for the intake feed, so I hacked up the stock air box inlet. I wrapped it in reflect gold tape but it started peeling after a few days, I'm debating painting black. It's the swiss cheese piece hahaha
@TyphoonFiST Might not be a Rocket Box, but hard to beat $25 at the thrift store, complete with instructions and all hardware. Looks like it was used a handful of times.
Test fit for a couple of longer trips coming up.
Where’s the propeller? Disclaimer: This comment was made in jest
CSM
Big day for the Jelly Bean:
  • New plugs
  • Oil Change (Amsoil 5w30)
  • Trans fluid change (Motul DCTF)
  • Picked up a set of Konig Dekagrams! 16x8
CSM
Nice. Onward and upward
For sure! Tires should be here Monday, I'll have them mounted Tuesday. 225/45/16 ZIII! Gonna sell my current setup. Yay for traction! (maybe?)
Traction? Lol they will stick like glue and you will wonder why you waited so long. Total transformation
maestromaestro
Sumitomos? I have them on my 993. These are good street tires, but they are STREET tires.
Dropped in an ITG filter and I loaded the stage 1 93 MAP. I also installed the AWR 88a RMM and a whoosh symposer delete.
What a big difference in feel and performance![lovest]
Next on the install list: whoosh v1 or v3 FMIC, whoosh silicone intercooler set, whoosh hot side j pipe, mountune induction hose, whoosh crossover pipe, whoosh v2 turbo inlet, GFB DV+, one step colder plugs, and a stage 2 MAP from Stratified or Dizzy.
