neeqness
LA
Seems like some bushings or something like that could help with the vibrations.
[MENTION=4438]M-Sport fan[/MENTION] - But I thought you changed your oem springs.
No sir, I am still on TOTALLY factory stock suspension right now, right on down to the steel NVH weights on the front struts.
But yes, I DO plan on upgrading to either some form/brand of coil over setup, or at the very least, Koni Sport yellow dampers with Swift Spec-R springs. ;)
There's a small amount of vibration at idle and then up to...maybe 1,500 RPM. After that, nothing.
Not hearing that stupid thud and a firmer shift is very much worth it.
In all honesty though, my truck has a 7.3 PSD and the race car has solid motor mounts, a crazy cam, solid lifters and high compression, so I really am used to vibrations!
Yes, there is what I call a 'noticeable rumble' at COLD start out in first gear at around the revs you've mentioned (and a VERY quick rumble at just cold static, clutch in, start), and to me at least, NO actual idle vibration I can notice/feel at WARM idle.
The ONLY time it is VERY noticeable to me is when the engine is LUGGED at all, whether cold (when it is quite obvious), or hot.
But let's face it, the engine should NEVER EVER be lugged under ANY circumstances!!!!!
Charlotte
My 7.3 lives to lugg! Lol
Peoria
If you don't let your car warm up you're compromising it's life. I wait at least for the first temperature bar to appear.
Kazz
Peoria
Just installed one of those the other day. Then had the seat heaters installed in my standard seats. Dropped by the dealership to show off the hot seat I had them put in the deal, and the first thing he spotted was the e-brake decoration. He was pretty impressed!
Prescott
I installed my Accessport. Wow did the car really wake up! Now just trying to figure out where to mount it???
brbauer2
St. Charles
I have one too, its great what a little thing can do, good on ya
Sometimes the littlest things make the biggest difference!
As for today, got some garage time in!
Boomba RMM
Boomba Transmission Bushings
Diode Dynamics LED Fog Lights
installed on passenger, stock on driver
I marked cutoff of stock and aligned the LED, but we'll see how it is tonight.
Drained my OCC for the first time, near 2250 miles. Seems like a lot, possible issue?
Picked up a set of Euro lights last weekend. Both sides need some mount repair done, but I've done it before and it's fairly easy.
Hit 3000 miles last night.
Harvest
I just unplugged it and put it in the house. Don't see any real need for it to be constantly connected.
joesiris
Lexington, SC
Boomba RMM
while all the rmm on the market all pretty much do the same thing, that one really looks cool, I really dig the red, and even though you cant really see it unless you are under the car you know its there and that counts
Do you do mostly very short trips with this car, which do not let the oil heat up fully (and burn off combustion blow-by, 'wash-down' fuel, and condensation moisture)?
That is usually what that symptom of a 'mocha milky' layer in the above pic suggests is the cause. ;)
Did that glass REEK of raw, un-burnt fuel??
brbauer2
St. Charles
60 minute/34mile round trip commute to work M-F, occasional around town errands, and 160 mile round trip every few weeks. Definitely smells of fuel, but not overly strong.
Sent from my OnePlus 3
