Clyde
Finished up my install of the gtx turbo and cpe intake. Loaded freektune base map and fired it up. All seems well :) No time to drive it till tomorrow.
How long did it take you to install it ? It's not something I can do but eventually I will go this route.
Brick
Installed Denso ITV22 spark plugs. Easy install. Smoothed out the idle & feels a little more responsive. At 3000 miles I will pull the plugs & check for fouling.
rswoody
trowbridge
Today i replaced my bov with a turbosmart one
it works well , it's now holding boost better
it was run 22 peak holding 20psi now peaking 25 holding 22psi which my map is set at by peron
happy days well until funds available full stage 3
Alameda
Took a couple shots of some things that went on the car earlier in the week with the GTX2863. Tial bov and Cpe intake.
Charlotte
Well I got my shift boot in the mail, although I don't know if I should pitch a fit about it or not. Advice? Or maybe a way I can salvage it a bit?
Charlotte
Well I can get it to fit in the car with no issues, my issue is the stitching not running all the way to the top on the right side. If it was facing toward the front of the car and I didn't have to see it, I wouldn't care as much.
Charlotte
Yeah the reverse lock-out collar won't let me go any further than that. Without cutting it, I really can't see a way around it.
Edit: So I emailed them, and this is the response.
"Hello!
that is normal. Since the boot you have ordered is tight on top, the sewing machine won't go all the way in - it's header has a certain size and it just won't get anywhere.
This is NORMAL with the kind of boot that you have.
Please just try to install it so that the shorter stitched edge faces the FRONT of the car. This way you will not be able to see it while you're in the driver's or passengers seat and it'll look perfect."
The shift boot doesn't quite go around that way...well this was my feeler for the rest of their products, not looking very good so far.
MOFiST
Adelaide
"Hello!
Wow that's a little rough. Maybe get a needle and thread out and do the rest by hand? I doubt it will look perfect though. That's what they should have done with the same stitch.
Charlotte
Yeah that's a few hundred bucks they'll be out (not that it matters), that i'll spend on a local shop to make the items for me instead. Oh well.
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
Depending on how much you use fogs it will burn a nice hole right in the center of that vinhl.
I never had them burn a hole but they did turn brown.
The problem is that the bulb is too close to the lenses.
I suggest that you change from a 55W to a 35W bulb.
Or not use the film at all and change to a 2500K (yellow) blub.
Dave
