Weird clunking noise front right passenger wheel.
Original J-Pat
SoCal
I have 123k on my 2014 fiesta st with stock suspension and I will sometimes get this clunking noise. I can go a whole drive and hear nothing and sometimes it's obnoxious like something is loose. I had a trusted mechanic friend look at it and he said it was probably my strut. Visibly I cannot see anything wrong so is that my best bet? He said just to replace them, and I have the cash and probably will do all four and do Bilstein B8's with swift springs since I have the money and wanted a better ride. Anything I'm over looking?
Passenger side Engine Mount top Bolt likes to break if its still an OEM mount*
Fiestig
Pacific Grove, CA, USA
If it makes the noise when turning (right mostly if I recall) into an incline driveway, it will be your sway bar bushings which do wear and will cause a random "clunk".
Original J-Pat
Original J-Pat
SoCal
I think you and pixelzombie might be right because I can't see the endlinks unless I jack the car up.
Fiestig
Sway bar end links and bushings are both very simple cheap fixes. If you do the sway bar bushings (which you should do anyway if you do the end links) be sure to get swivel head ratchet. It makes sway bar bushings a 15-20min job
Original J-Pat
Original J-Pat
SoCal
If itā€™s only when you turn- consider looking at your hub bearing.
Turning doesn't bring it on more so when the road gets bumpy. With that said it's been a pretty bumpy ride some days and I don't hear it at all.
Original J-Pat
Original J-Pat
SoCal
It's sordove under the coolant reservoir * So it's not put in the open.
I checked all those bolts, and they look fine so I'm guessing the best guess from everyone else on the sway bar links is probably my problem.
Original J-Pat
SoCal
To update this replaced front sway bar links and noise is still present. Bought b6 struts for all around and swift springs. Doing all corners since I'm at 125k on the second engine.
First time is a pain because it takes some understanding on how to get to them. Very simple to do especially if you have a swivel head ratchet. From under the car look at the top/rear of the front subframe and you will see them. Alternatively you can also see them clearly with the front wheels off and the endlinks disconnected
