Wagners site, however it now appears they have fixed a few of the errors.
Finally got around to putting this in this weekend.
It both does and does not fit.
It is definitely for EU cars and will not clear the crash bar if installed as intended, mounted ahead of the crash bar. However, given the big difference in relative positions of our crash bars, this means there is significant room behind the crash bar, and being a determined guy, I figured out how to make it work.
Believe it or not, the stepped core intercooler will slide right in behind the crash bar with a little finesse after unbolting and removing the original plastic mount pieces from the radiator core support piece. I used the hood latche's center spar to support the FMIC using the threaded hole in the top of the FMIC. The chargepipes will mate up, as is, but I trimmed the passenger side one down about 3/4in to make it connect without kinking.
Once that's done, it all fits behind the bumper within the confines of the stock bumper.
To keep airflow going to the FMIC I moved the flap that traps air on the underside of the crashbar and relocated that on top of the crash bar to seal it up there instead.
AP is currently MIA so I have no idea what changes in air charge etc are. On stock tune, stock airbox, stock downpipe w/ a muffler delete.
so you can buy it, and it will fit without cutting up your bumper or crash bar, but it won't fit as it is intended to.
Pics coming
