Vudu Catless Downpipe Install and Review
VirtualRonin
Active Military
Spring Lake Park, MN
I installed a Vudu catless downpipe this evening with an new exhaust.
Very nice looking downpipe and the part that I really liked was the 2 bolt bracket so I can retain the factory support bracket on the RMM.
This did not come with any bolts for the bracket or a new gasket where it mates to the exhaust. That would have been a bonus
I did have some trouble mating it up to the turbine housing. It was a really tight fit, like an interference fit. I basically had to get it lined up on the turbine housing and tighten the nuts down evenly to press it into place.
The bracket lined up fairly well and bolted into place with no issues.
CarGuy
Daytona Beach, FL, USA
Curious about the differences between it and your Mountune setup. You had the catted Mountune downpipe before? Is the new one the same or catless?
VirtualRonin
VirtualRonin
Active Military
Yeah, the Vudu is catless
Indianapolis
Is the flex joint on this dp fairly flexible? one of the reasons I like these type of flex joints is the flexibility compared to the more traditional ones.
VirtualRonin
VirtualRonin
Active Military
Besides a little louder, what other differences did you notice?
The turbo seems to be spooling up faster. I'll have more details on that once tuning is completed and I can make a good comparison against my catted setup.
VirtualRonin
VirtualRonin
Active Military
Yeah, I would say the bellows style on the Vudu is a little more flexible than the the standard joints.
VirtualRonin
VirtualRonin
Active Military
Here's a V-Dyno comparison of Catted (High Flow) vs Catless. It hits full boost a bit quicker plus some gains in HP and TQ.
Easton
Here's a V-Dyno comparison of Catted vs Catless. It hits full boost a bit quicker plus some gains in HP and TQ.
What happened between 5k and 6k?
Sent from my Pixel 2 XL using Tapatalk
VirtualRonin
VirtualRonin
Active Military
Thread Starter #12
The catted runs were a few weeks ago so nothing stands out as anything happening out of the norm, that's just how the data was logged. I did other runs that were about the same with the catted downpipe but this datalog seemed to graph the best out of the ones I have available.
CarGuy
No offense but like I keep saying it's not worth polluting 100% of the time for a few hp. To each his or her own but to me seems not worth it. Thanks for sharing!
VirtualRonin
VirtualRonin
Active Military
Thread Starter #14
None taken. Just out of curiosity, what kind of gains would make it worth it in your opinion?
My cat was not stock so going from a stock cat to catless would likely be a much larger jump in HP and TQ but that info is already out there.
Kl
What exhaust do you currently have? This plays a large roll in drone...not so much the Catless DP. [raceflag] I'm sure Brian/Bryan will chime it though!
using stock currently, but looking for catless DP...any good to intro that doest drone much?
