Vibrations engaging clutch
Kansas City, MO, USA
When I engage the clutch in first gear, i get vibrations around 1k to 1500 rpms. Almost like when ur going to slow in a gear vibrations. Anybody know what this could be? Do i need a new clutch or my flywheel resurfaced?
kivnul
U.S. Army Veteran
Deer Park, WA
Are the vibrations while you are still engaging the clutch or after you have fully released the pedal? How many miles on current clutch? Any aftermarket goodies that effect HP? Brake fluid reservoir at the proper fill level? Any fluid seepage / dripping under the transmission?
If you are not getting clutch slippage when you give it the beans, I am doubting that you have a problem with the clutch & flywheel. It could be something as simple as worn out / broken engine & transmission mounts. Also could be a failing slave cylinder.
Welcome to the Forums!
