The HP ratings on IC's is a bit arbitrary, many factors to consider.
The J-Line is a great value and probably more than enough for most needs and may of for mine but I had to shave off some weight. I most highly recommend it as a great budget IC unless somebody wants some thing lighter in weight but for most the tradeoff is well worth it.
I mentioned the far more expensive Cobb only because it is lighter and for those with a car with a lot more weight taken out of the rear than the front it helps balance things out. My car was unstable at 130MPH and jumping on the brakes due to a bit to light in the rear so I had to top off the tank all the time. Though Cobb has less mass and less volume could effect the end results a bit but the added exposure to direct air flow will make up for some if not all of it, in the right situation.
The DHM on a hot day with in the 300WHP range on a road race track, that is why I went that route as was not sure the J-Line or Cobb would do what I needed. Added weight is only around 4lbs over the stock setup and the price is amazing for what it is. It would likely be overkill for many.
