very sad indeed, and a good reminder to check for exhaust leaks. My FSWerks exhaust leaks all over the place and I am not happy about it. I picked up a new Cobb exhaust gasket and will install that and go through all of the connections again. Leaks can be deadly and you may not even know there is a leak without any clues. I was noticing sound coming from under the firewall when I would be against a wall or car with the window down (drive-through) and noticed carbon deposits on the garage floor. Even with following all of the suggested torque values and adding Loctite after everything loosened up a few times last summer, it is back leaking again this spring.
