I'm trying to understand the fists vacuum reading at idle. Sometimes it will be -10.5 ish, sometimes it will be -10 ish,And sometimes it will be -9.5 ish. But it doesn't violently fluctuate. For example, if I'm at a light for a while and the reading is -10.5. It will stay at 10.5 for a long time. Then I'll start driving again, and next time I come to a stop I'll notice it's closer to -10 or -9.5. I've also noticed the vacuum reading is different depending on if the car is on a hill or incline, so this may have something to do with the slightly changing reading? Is it normal for the fists to do this? And if not what would cause this?
I'm also trying to figure out everything that could impact a vacuum reading. Can you guys tell me if any of this stuff could slightly impact my reading? And also if I'm missing something?
-being on an incline
-Vacuum leak
- different weight oil
-Too much oil or coolant
Different spark plugs (step colder etc)
Whatever else may affect vacuum at idle
-Vacuum leak
