- Member ID
- #9799
- Messages
- 129
- Likes
- 133
Congrats @PlatinumFiST ! My LED strips don't flicker at all. But then again I've done the wiring change so hopefully that's all you need to do. Which H1 bulb retainers did you end up with?
Some updates to report...
1. I haggled with Cars245 and got 26% of my order credited - $92 - i used it to order the replacement which arrived in perfect condition in 3 days. I am no longer using a zip ties to hold my passenger headlight quasi aligned. Now to find a good article on proper headlight alignment techniques. I would still say it was a so-so experience with Cars245. The order of events was...They offered 20%. I countered at 35%. They credited 26% without my approval and stopped communicating. At least i got something back. I plan to crack open the busted unit and glue the adjuster back on.
2. Due to the zip ties, i was running the passenger side without dust covers. The driver side had dust covers. I noticed that the driver side would get condensation in it but the passenger side never did. So I removed the dust covers from the driver side and viola, no condensation on that side either.
3. On a long drive to the city one night, my driver side LED went out. Flicking the switch on and off would get it back on but it would go out again in a few minutes. I suspected it was heat so I removed the dust cover and hung the mini ballast outside the headlight. The bulb stayed lit. I since moved the bulb over to the passenger side to see if the issue follows the bulb. It hasn't... yet. No dust covers on either headlight at this point.
Still VERY happy with the lights!
I used some bulb holders that I was somewhat skeptical about until I tried them, they work just fine but there is no real locked position, they just grip the bulb collar and slide in to the h1 slots on the headlight. Alla Lighting H1 LED Headlight Bulb Adapter Holders https://www.amazon.com/dp/B07R7S171R/ref=cm_sw_r_sms_awdo_btf_t1_XfrGFbF4TJ3PX
I wonder why the people at cars245 weren't willing to communicate. And 35% doesn't seem like too much to ask for in my opinion.
Shame that one of your LED bulbs is giving you trouble. I had the same happen with some auxbeams I bought secondhand. It didn't seem like it was heat, since it would die out again after another 2-3 minutes. I think it was just a faulty bulb.
Sent from my LM-G850 using Tapatalk
