Just wanted to share my experience with my other car, which is that cutting bump stops in some applications is absolutely necessary. I lowered it about 2/3" F and 1" R on Tein S-tech springs, which are supposed to ride about like stock. The ride instead was very harsh, hitting very hard on minor road irregularites and manhole covers. It turned out that Tein rec's cutting the oem bump stops about 2/3" in the front only, about the same as the amount lowered. I guess the front of an NSX has less travel. In fairness to the mechanic, the instructions were on an obscure place on Tein's site, but he was supposed to be a specialist and should have figured this out.
After lots of research I figured out why the ride was so harsh and had to have new bump stops, properly cut down, installed. This helped the ride harshness a lot, as the mechanic who did this said it looked like the car was riding on the bump stops about half the time before. If you're riding on the bump stops, you basically have no suspension.
So I would pay careful attention to whether they need to be cut down.
