Moving a battery to the rear can be done for several reasons, get weight off the drivers side of the car up front, balance front to rear if removed more rear weight than front, etc...combined with a lower weight battery it can drop quite a bit of weight as the stock mount is pretty heavy. I took all that out and am fabricating an aluminum ECU mount. I also found the upper transaxle mount is quite robust as part of it so made a new lower weight mount cover with tighter tolerances to control the movement in the factory mount. I have asked several vendors to come up with an insert for others that would just want it to help with wheel hop, etc....
I will have the WMI kit, tire repair kit, small amp and sub in the rear(quick disconnect on the amp and sub for track days but leave it in if the car behaves better under hard high speed braking)
Big Crank batteries are well regarded and much less money that other AGM batteries, I have the 14 series but finding I need a bit more battery now that I installed an alarm but also just realized I have been running the wrong charger on it so have to replace it anyway, glad it did not cost much.
I have an Odyssey 680 I was going to install but it seems it died when I forgot to charge it before it was in 8 degree weather, it was in storage for quite some time and I did not take care of it
It is not rated much differently than the 14 series below.
I also have a 1200 but 39 lbs is far to heavy, going to put it into my daughters 4 runner if OK in AZ heat, will check that out first.
BatteryMart, Big Crank
14 series, $85, 14lbs, 12ah, 220CCA, worked perfectly fine but would run down in a week or two so if not driving, started the car on very cold days just fine if charged up.
30 series, $107 shipped, 26a, 400CCA, 23lbs is what I will order today.
I really wanted the LI battery but not at the $725 price! With 10% military discount best I found it is still just to much money. Reason for such and expensive battery is matching the charging current to the battery, at least EarthX says I must do so for it to last.
